Tv box fault
7 REPLIES 7
BethanySarah
For a week now my tv has been only part recording or failed recording all scheduled recordings. It also doesn’t always turn on with the remote button. I am having to continuously press the restart at the back of the box at least 2 times a day!
Please let me know what I can do to fix
fre55die
Hi @BethanySarah
I should try a maintanence recet option 2 as TT are no longer supplying recording boxes on here :
Maintenance Reset Option 2 (Keep Recordings)
Turn the box off, then unplug the power lead for about 10 minutes.
Re-plug in power  lead.
  1. Ensure the YouView Box is switched off and is currently connected to the router (the YouView Box will require an internet connection).
  2. Power on YouView using button at the back of the YouView Box.
  3. Start YouView using the power button on the YouView Box front panel and then quickly press and hold both the + and – buttons on the front panel. If you haven’t pressed the buttons together by the time 'YouView Waking Up' is displayed, or you see the 'YouView please wait...' message then try again.
  4. Let go of the + and – buttons once the 'Huawei – Maintenance Mode menu' is displayed.
  5. The + and – buttons on the front panel will navigate the menu. Keep pressing the – button until 2  “factory reset keep recordings” option is highlighted.  If you go past the option, simply press the + button to navigate back to the option.
  6. Press the power button on the YouView Box front panel to select the option. This will bring up some information and ask 'Do you want to proceed?'. Press the power button again to confirm.
  7. The YouView Box will now show a progress bar as it downloads software from the internet and installs on the YouView Box. This may take several minutes. Once complete, the YouView Box will restart.
  8. Once the YouView Box restarts, the YouView Box will show the initial setup wizard. You will need to run through the setup wizard including tuning the channels.
You will then need to reset your personal settings (such as parental controls / ANTENNA OUT / Surround Sound etc.) and also probably reset your scheduled recordings (It might be worth taking a note of future recordings before doing this so you don’t miss any).
If you do NOT have any recordings that you want to keep :
Blue YV /Menu button on the remote  >  Settings  >  Factory reset. This option will re-format the hard drive and reinstall the system on your box and you will lose all recordings.
Again It is also a good idea to restart your router once you have done this.
OCE_Karl
Follow the advice from fre55die and let me know if this helps.
BethanySarah
This has not helped. In fact the box is now worse. All my recordings have disappeared and it will not let me schedule new recordings. I also cannot see anything when the menu button is pressed. Says code YVM401 but nothing on the website helps.
My TV guide is invisible and it will not move off of one channel
fre55die
HI @BethanySarah
How is your box connected to your router? Is it directly with a cable or via Power Line Adapters ?
OCE_Karl
Hi BethanySarah
we can replace the box however TalkTalk no longer supply a recording box and only now supply the Lite Box.
Would you like me to send one of these ?
BethanySarah
The box seems to be working fine at the moment. Thank you.
OCE_Karl
OK, Thanks for letting me know.
