on 26-04-2021 10:07 PM
Have been having to reset box for the last week to be able to watch youview and all my recordings are failing. Have tried everything to fix it, can you send out a new box
on 27-04-2021 02:08 PM
No Problem 🙂
on 27-04-2021 01:28 PM
Hi Karl
That's great, thanks for your help
Thanks again
John
on 27-04-2021 12:33 PM
Hi John,
Box on the way.
on 27-04-2021 11:45 AM
Hi Karl
I've just tried these again and the box has completely stopped working now, so if you could send me the new box that would be great.
John
on 27-04-2021 09:41 AM
Hi John
You can try the Youview Maintenance Reset and if this fails then your only option is to try the full factory reset from the settings menu to remove any corrupt files.
If all else fails, I can send another box however this would be the Lite Box as Talk Talk no longer provide a recording box.
