Tv box problem.
Paushe
Message 2 of 2
Hi.
I have a huawei DN 372T Box that over the last couple of weeks has started misbehaving.
The pictue is pixilating and image and sound cuts out ( black screen) with a cracking/clicking sound for 5-10 second then comes back on with the option bar on the bottom of the screen.
My recordings are also affected , even overnight recordings with tv off.
The problem doesnt occur watching tv apps e,g Amazon, Now tv Youtube etc.
I have done a factory reset, rebooted the box, unplugged overnight, retuned the channels and even re booted and repositioned the router.
I am getting 50-54% signal strength 100%quality.
I am using rg-6 Coax, hdmi and cat7 ethernet cables.
Am i missing something or does the box nreed replacing?
1 REPLY 1
Message 1 of 2
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if you are reporting a fault.
We will then reply via this thread in our Community with any further advice or next steps.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you.  Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
Please post back on this thread when this has been done.
