on 21-08-2021 07:27 PM
Tv box is not connecting to router. Tv light on router not flashing. Using power adaptors
on 23-08-2021 07:35 AM
Hi Clare25
Did you follow the advice from fr8ys, and did this help ?
on 21-08-2021 09:30 PM
Try the following in this order.
Soft reset your box by pushing the on off button until it restarts. If that fails...
Try resetting your powerline adaptors and repairing them.
If that fails, reboot your router. If that fails turn your router off for 30 minutes to establish a new session.
This will either confirm or eliminate the connections between the router and the box. I have assumed you have taken out and replaced the leads to ensure these are in fully.
If its still not working then have you tried a YouView Maintenance Reset? (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
