Tv box
Nick1963
Message 9 of 9
Tv box keeps cutting out
8 REPLIES 8
Message 1 of 9
No Problem 🙂
Message 2 of 9
Hi Karl
Thank you for your help
Message 3 of 9
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Message 4 of 9
Hi Karl Blank screen & lights go out on box no error message can restart then 5 minutes later off again
Message 5 of 9
When you say it cuts out, can you describe what is happening. Is it just a blank screen, is there an error message, do the lights on the box go out etc.
Message 6 of 9
OK thanks for clarifying.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
Message 7 of 9
Hi I have tried all this & same problem keeps cutting out have to restart then in less than five minutes cuts out again await your reply thanks
Message 8 of 9
In what way and what have you tried to resolve the issue? Does this happen when you are doing specific tasks?
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
