Tv not working after fibre 35 upgrade
Sadie underwood
Message 3 of 3
Plugged cable into new router  tv box says no broadband. Using 13 amp connecting plugs. No lights on router end.
Message 1 of 3
Hi Sadie underwood
Are you using homeplugs to connect the TV box to the router ?
fre55die
Message 2 of 3
Hi @Sadie underwood
See this article, you need to connect the router to the internet and the router to the box. :
https://community.talktalk.co.uk/t5/Articles/Setting-up-your-TalkTalk-TV-Box/ta-p/2204453
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
