Tv plus box dead
essexjones247
Chat Champion
Message 5 of 5
Hello, my tv box is dead, it started with stopping playing watching recordings, I did a maintenance mode factory reset which seemed to make it work for a while now there’s no lights on it at all and appears dead, are there any OCE who can send me a replacement ASAP
4 REPLIES 4
Message 1 of 5
No, the lite box does not have this and an external device cannot be connected.
essexjones247
Chat Champion
Message 2 of 5
Thanks for the reply, does the non-recording box have PVR functionality so that if I attach an external hard drive it will allow me to record programs?
Message 3 of 5
Hi essexjones247
we now only provide the Non recording box, and can send this if that is ok ?
Birchcroft
Message 4 of 5
@essexjones247 Unfortunately TalkTalk no longer supply TV boxes with a  recording capability.  So any replacement they may, or may not, provided will lack to ability to record/replay programmes.   So if you want a box that is capable of recording then you will have to buy a 3rd party Youview box manufactured by the likes of Humax or Manhattan.  Note, if you use TalkTalk TV services then make sure you get the Youview box rather than the Freeview box
