Unresolved YMV102 and related error messages
CitizenMarc
Message 3 of 3
For some time our YouBox (TT supplied, Huawei, c 2yrs old) has been playing up (slow MyTV navigation, etc) but since 2 days displays 'no broadband connection', error messages YVM102 and 105, cannot display Watch List page; lacks Guide info on all package channels; cannot access Prime channel to watch my Wales international tomorrow etc.
I have followed all recommended remedies to the letter: rebooting router and powerlink relays, switching off YouBox etc. Wifi is performing fine to router, mobiles show 70mbs or better; Alexa / Echo devices all AOK; Smart TV (getting its wifi through the YouBox connection to wifi via an ethernet cable) is able to access wifi with no problems....
YouBox software and apps all up to date. 45% space available on YB drive.
I spent almost two hours on Chat today - a total waste of my time that I badly needed for another commitment. I was cut off without notice three times - twice after beginning to get them to run tests.
Even after clearing security the Agent asked questions I thought they should have had the answers for on the system - what YouBox  model, obtained how, what broadband package and how TV being accessed.
I have ASD and the experience grew increasingly distressing - it's as if the TalkTalk system rides rougshod over both agents and customers - but the paying customers at least deserve a decent, reliable service.
I gave my alternative phone numbers to two of the agents, asking them to phone me should I get cut off (this has occurred everytime with TalkTalk, whether on the phone or on the Chat line) and neither rang me back as requested.
I feel badly let diwn by TalkTalk, again.
Marc Evans
Message 1 of 3
Hi CitizenMarc
If you can follow the advice from fr8ys and then report back, we can pick this up for you.
Message 2 of 3
To check that your powerlines are working, can you take the ethernet cable out of the box and plug this into your smart TV so it should switch from Wi-Fi to direct connection, and try accessing IPlayer. Can you connect? If yes then this should rule out the plugs. If you cant connect, then you will need to replace the plugs.
If you have ruled out the plugs, then the fault would appear to be with the box.
Try a soft reset. To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then try a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347).
Hope this works and please let us know how you get on.
