Volume button
Lollyloc
Message 4 of 4
The volume button on my remote has suddenly stopped working.
3 REPLIES 3
Message 1 of 4
I'll get a remote to you.
Lollyloc
Message 2 of 4
Hi I've tried all of the above
Message 3 of 4
have you tried changing the batteries?
have you tried resetting the remote?
https://support.youview.com/youview-box/box-and-remote/reset-your-remote-control/
if this does not work, try a soft reset on the box? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you try a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347).
Hope it works but if not then please let us know and the support staff will look into further.
