Wake up
Don473
Message 4 of 4
Hi, my tv plus box is stuck in wake up.  I have switched the power off for a while (30mins), and attempted a reset, but i can't get past the wake up page.  I notice there is maintenance scheduled at an exchange near me, but i don't believe that should affect my service.   Can you suggest a remedy?
“When plunder is a way of life for men, over the course of time they create a legal system that authorises it and a moral code that glorifies it.
3 REPLIES 3
Message 1 of 4
No Problem 🙂
Just glad it's getting sorted out for you.
Don473
Message 2 of 4
Thanks for your advice Karl, i called the service No before seeing your reply and they are sending a new box.
Message 3 of 4
Can you add your home phone number to your Community Profile so I can locate your details.
If the box is stuck in waking up then it has failed completely.
