Which cable
Pash02
Super Duper Contributor
Message 7 of 7
Hi I have just bought a ultra 4 k TV
Now to get the best results which ethernet cable should I use cat 6a, 7 or 8 to connect the TV to my WiFi hub?
My down load Speed is 65 mbs.
The TV is a Samsung QE50QN94A
https://www.richersounds.com/samsung-qe50qn94a.html
https://www.kenable.co.uk/en/networking/network-patch-cables/ethernet-cat8-patch-cables/ethernet-cat...
6 REPLIES 6
Message 1 of 7
The Samsung e-manual is well laid out and the index is linked to the contents. I found the CAT7 recommended cable type fairly swiftly. I hope that helps you to enjoy your new TV all the more.
GondolaVolunteer 2017-2022
  Like below to appreciate my help . . . Mark as solved  Accept as Solution
Pash02
Message 2 of 7
Arr yes the Manual not even got round to reading that but i did only order the TV yesterday..
Gondola
Message 3 of 7
Hi @Pash02
The Ethernet port specification is 10/100 so the maximum speed is 100Mbps. However, the e-manual recommends CAT7 shielded twisted pair for the connection. The need for this higher specification cable is not for the higher speed but for the screening to avoid interference pick up.
Message 4 of 7
Until your telly, internet and router are capable of carrying speeds of more than a gigabit you'll be fine!  🙂
Pash02
Message 5 of 7
I thought it may need a high cat for speed or something.
Message 6 of 7
Cat 6 will be fine, anything else is overkill for such a simple connection.
