You View Box
BRENN7UTD
Message 2 of 2
While watching anything on BBC I Player or ITV Hub etc, half way through, the screen suddenly stops and goes back to the normal TV station. I then have to go through  the normal procedure  to get the programme or film I was watching  back on. Not sure if my View Box needs replacing. Thanks
CB
1 REPLY 1
Message 1 of 2
Try a Youview Maintenance Reset  as this will remove the apps and download / install them again to remove any issues or corruption with the app files etc.
See if this helps.
