You view box not working
Bob227
Message 19 of 19
My you view box is not working, no life in it at all. Only had it 18 months. Can i get a replacement?
Bob Edwards
18 REPLIES 18
Message 1 of 19
Thanks for letting me know.
Bob227
Message 2 of 19
Account ok now thanks
Bob Edwards
Message 3 of 19
Hi Bob,
There is a stuck order for a TV box that was rejected.  I'll see if I can cancel the order from here.
Bob227
Message 4 of 19
On my account it shows an outstanding order, for a you view box, when I try to change anything on it a message comes up to say there are outstanding issues.
Bob Edwards
Message 5 of 19
Hi Bob
what do you mean your account is blocked ??
Bob227
Message 6 of 19
my account is still blocked
Bob Edwards
Message 7 of 19
Hi, @AnnaW3
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
AnnaW3
Message 8 of 19
my view box is not working, I've had it around 5 years, I've checked power, all fine, tried all buttons and checked settings following advice online, but its completely dead. Can I get a replacement? Anna
Message 9 of 19
Hi Bob,
Thanks for confirming. It may take a few days for the warehouse to book the returns against your account, but this should be done soon.
Message 10 of 19
The bar code is da539414727gb if that helps
Bob Edwards
Message 11 of 19
Sorry Michelle that should be received at your depot on Sunday.
Bob Edwards
Message 12 of 19
I posted them on Friday and they showed delivered yesterday morning.
Bob Edwards
Message 13 of 19
Hi Bob,
Just to confirm, how long ago were they returned?
Message 14 of 19
I have returned the 2 set top boxes and I can see on the post office tracking site that they have been delivered to you but I can see on my account still shows outstanding issues so I can't do any adjustments to my settings.
Bob Edwards
Message 15 of 19
Hi Bob,
Ok thanks for the update and please let us know if you need any assistance.
Message 16 of 19
Received replacement box and that didn't work, no life in it, but there was a slight damage to the box it came in. I decided to try my old box before I sent it back and it is now working ok. I rang TalkTalk to explain and was told to wait till another replacement box, which had been order after I had complained about the replacement box not working, to see if it is sent or cancelled before I return the replacement boxes to you. I know this sounds complicated but its all my own fault. Sorry for the confusion.
                           Bob
Bob Edwards
Message 17 of 19
I'll get a box out to you and a returns bag for the failed one.
Message 18 of 19
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones.
Thank you
