You view box
Candyfloss1
Message 3 of 3
You view box won’t connect to the router. Just receive message saying trying to connect waited for 10 mins or more but it doesn’t connect.
Message 1 of 3
Hi Candyfloss1
Are you still having an issue with the TV box connection ?
fre55die
Message 2 of 3
Hi @Candyfloss1
How Is the TT box connected to the router? Is it a direct ethernet cable or Power Line Adapters?
