You view box
Sarah Hesketh
Message 2 of 2
Can you provide a wireless Youview box. Or, if not, the hardware to enable the Youview box to pick up a wireless signal?
1 REPLY 1
Message 1 of 2
You view boxes are.not wifi enabled.
Some have been able to buy equipment to enable them to be used wirelessly but it is not guaranteed. You will find how to do so with a google search.
If you can't plug directly into the router, powerline adaptors are your best bet.
