YouView Box issues (TalkTalk TV+)
RWAP01
Message 8 of 8
It seems as though my YouView box has reached the end of its useful life - been having issues for months whereby it stops responding to the remote control (especially when watching a recording) and now channels are breaking up quite a bit (compared to watching the same freeview channels on my TV).
Even the light on the front has dimmed to almost non-existant.
How do you get a replacement box - as there is no way I can find on the site to contact TalkTalk (no live chat, nor even phone numbers showing)
7 REPLIES 7
Message 1 of 8
No need to return the box in this instance.
New boxes are sent without a remote as the current one will work with all models.
Message 2 of 8
Now received and set up thank you.  Do I need to return the original?  There was no returns label in the package.
I was also surprised that there was no remote control included in the box
Message 3 of 8
You're Welcome 🙂
Message 4 of 8
Thank you
Message 5 of 8
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Message 6 of 8
Thanks - I did try this some weeks ago and it still stops responding to the remote control every now and then.
Oddly it only ever seems to happen when watching a recorded program
Message 7 of 8
Can you try a Youview Maintenance Reset (Option 2: Keep Recordings).
Set the TV Box back up and see if performance improves.
