YouView Box not working
AlexRT565
Message 1 of 15
our YouView box is several years old and has been slowing down for ages. I have followed other posts on here for resetting it and so on. The other day it completely froze on ITV3 and the remote wouldn't work.
I switched off at the wall and waited before restarting. No change.
I switched off at the box and waited. No change.
I followed posts on this community page and went to 'maintenance mode' and did a software download but it has never recovered and when it restarted it got stuck in 'wake up' and now just says 'loading'. It's been like this since Saturday.
Do we need a new YouView box? This one is definitely getting on a bit and now is not working at all.
Thanks,
Iris
14 REPLIES 14
Message 2 of 15
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Message 3 of 15
Many thanks @Karl-TalkTalk
Message 4 of 15
No Problem 🙂
Message 5 of 15
Hi again,
we set up the new box, followed instructions etc and everything was fine for the first 24 hours, the TV seemed to work perfectly, no freezing etc as we had with the old box.
At night we turn the box off using the remote which we have always done. However in the morning when we switch on the box we are encountering a problem. All the channels are blank! We tried switching off at the button at the back of the box and waiting, no change. We switched off at the wall and waited, no change. We then retuned the channels in the Settings menu.
The first time we did this it said that no channels were found. (We checked internet connection, all ok). We immediately tuned the channels again, and all the channels were found. Hoorah! The problem was fixed.
But, the next morning, when we turned the box on (using the remote, as usual) exactly the same thing happened again! So it seems that if we turn the box off at the remote (which presumably we should be able to do at night when we go to bed?), the next day, we have to retune all the channels to watch the TV, and we have to retune them twice, because the first time always shows that no channels were found.
In addition when we switch the box on it always says "Waking Up" which we only noticed on the old faulty box when we reset it or it was going wrong. It never said "waking up" when we just switched on from the remote. I have no idea if this is an issue or not but thought it was worth mentioning.
Help much appreciated please.
Thanks,
Iris
DENNIS17
Message 6 of 15
Our youview box is very unresponsive,  I've changed the batteries in the remote control and switched the box on and off and reset, nothing helps. Getting very fed up with paying for something that doesn't work.
Message 7 of 15
Hi Iris
Can you try a full factory reset from the settings menu, then set the box back up and let it fully update any software.
Then see if the box does the same thing tomorrow.
Message 8 of 15
Hi DENNIS17
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
Check your home phone number or account number are also added to your Community Profile as that will really help us to find your details quicker.
Message 9 of 15
Hi @Karl-TalkTalk
I did a full factory reset and set up the box again on Monday and wanted to try it for a few days to see what would happen. It's fixed the problem in the morning, in that I don't have to retune the channels every day, but throughout the day I could be watching a channel and the screen just goes blank or freezes and I can't get off that channel. When the screen goes blank it still shows the channel number but there is no picture. If I scroll between the channels then they are all blank. I usually end up switching off at the wall and leaving it a few hours. When I come back it's usually fixed but then goes again a while later. When it freezes, the picture stays but when I change the channel they are blank.
I've checked the internet connection each time but that appears to be working. I've restarted the router at a different time to make sure but internet is fine.
I didn't have this problem with the old box except the freezing issue. The blank channels is a new thing.
Help appreciated please.
Iris
Message 10 of 15
As this is a new box, I'll also get a new router out so we can make sure this is not failing.
Message 11 of 15
Hi @Karl-TalkTalk
the new router arrived and we set it up and have tried things for a few days. For the first day it seemed that things were better and we weren't experiencing blank channels and having to retune all the time.
However, the same problem is back, and when we retune the channels, the first time it says there are zero aerial channels. I then immediately retune again which seems to work and all the channels are there and the tv comes to life again! We are doing this a few times a day to be able to watch TV.
Unfortunately this seems to be a problem with the new box that was sent out as although the old box kept freezing (it was very old), we didn't have problems with the channels.
There is also another new issue with recording on this new box. When we try to record a few different things can happen; 1) it knocks the channels out, so we have to retune 2) it says it's recording but isn't 3) it says it's recording and appears to be, but when you try to watch back it says "failed recording" or it's only recorded half the programme.
In some way I think I preferred the old box as it was just freezing, now we have all these additional problems!
I am quite happy to watch TV from the aerial but the only thing I want is a recording facility. I have found that I can buy a TV with built in freeview and a USB recorder which would mean that I don't need TalkTalk TV as this is all proving very frustrating and time consuming.
I am happy with TT phone and internet, but if I were to drop the TalkTalk TV do I have the option to opt out monthly or do I have to wait for my contract to expire?
If you have an idea of what could be wrong please do let me know and info about opting out of TT TV as well would be really helpful.
Many thanks
Iris
bjordan
Message 12 of 15
Just spent ages on Talk Talk chat about my box failing to pre-record programmes & also the box not responding to the remote. The adviser says she did tests & there was nothing wrong with the box!!! She suggested it was a reception problem & I should contact an aerial engineer. I tried very nicely to tell her the problem is the box so she suggested I could buy a new one for £50!!!
Come on Talk Talk please help me out.
Brian
Message 13 of 15
Hi Alex
The only option we have would be to replace the box.  To opt out of TV etc, or for the cancellation of any part of a service, call our customer loyalty teams and they can look at this for you.
Message 14 of 15
Hi Karl
Thanks for getting back to me. I think a new box is the way to go to hopefully resolve the problem.
By the way the name's Brian not Alex.
Kind regards
Brian
Message 15 of 15
Hi Brian
The reply was to Alex the OP.  I've replied on your thread separately.
