YouView box laggy
mh464
Message 8 of 8
My YouView box is often laggy, taking a long time to respond, especially when trying to use the apps.  I've tried resetting it a couple of times (including the maintenance reset) but hasn't made any difference unfortunately.
7 REPLIES 7
Message 1 of 8
No this will not cause a problem, I'll sort it all out.
Message 2 of 8
Hi Karl,
The new remote has arrived and everything is working well.  I have the old TV box ready to return, however I received an email asking me to return my WiFi hub but not the TV box.  Is this going to cause a problem?
Message 3 of 8
I'll get a remote out to you.
mh464
Message 4 of 8
Hi Karl,
The new box arrived and is working great, we've got HD channels back too (not sure if that was the box itself or something else, but all working again).
I see the new box did not come with a new remote, while mine still works, the rubbery coating on the back is starting to come off and disintegrate, would it be possible to get a new one?
Message 5 of 8
You're Welcome 🙂
Message 6 of 8
Thanks Karl!
Message 7 of 8
I'll get a TV box out to you.
