on 02-07-2022 05:53 PM
YouView Box will not wake up
on 04-07-2022 01:25 PM
I sent it to the 'JohnT37' account now too.
on 04-07-2022 01:22 PM
Hi Karl I did as you said but the latest message was 2019
on 04-07-2022 12:29 PM
you can use whichever username is easier for you 🙂
on 04-07-2022 12:26 PM
Sorry Karl my old username just cropped up should be JohnT68
on 04-07-2022 12:24 PM
PM = Personal Message.
Click your Avatar image (top right) then click the envelope symbol to read your messages 🙂
on 04-07-2022 12:21 PM
Sorry Karl, I'm a bit out of touch. What is a PM?
on 04-07-2022 08:12 AM
Hi @JohnT68
I've sent you a PM.
on 04-07-2022 08:08 AM
Hi John
I'll get a TV Box out to you.
on 03-07-2022 01:23 PM
OK, it may have met its demise. The support team should be able to arrange a swap out for you, but bear in mind that recording boxes are no longer available. If that feature is important to you then you will have to seek a third-party alternative.
on 03-07-2022 11:07 AM
Hello Ferguson. You a Billy Cotton fan?
I have Huawei DN372T. I have now carried the test you mentioned. I get to item 4 and get no start screen.
on 02-07-2022 05:56 PM
Have you tried shouting "wakey-wakey?" 🙂
Otherwise, have you worked your way through the Maintenance Mode resets?
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode/
