YouView settop box stuck waking up
WelshNess
Message 6 of 6
I have checked all the cables and tried a software reset. The box is stuck with the red and blue lights on the front flashing and doesn't get beyond this stage.
5 REPLIES 5
WelshNess
Message 1 of 6
Thanks so much for your help  @Karl-TalkTalk and @fre55die
Message 2 of 6
Hi WelshNess
A replacement TV box is on the way to you.
Message 3 of 6
@WelshNess
As I said the Staff can't trace your account from your screen name so Could you please ensure that your personal information is up to date in your profile INCLUDING your registered landline number
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info.
This is purely so that the OCE's can tie up your details and trace your account as this is not possible from just your screen name.
Thank you.
It could well be a PowerLine Problem by the sound of it..
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
WelshNess
Message 4 of 6
Hi @fre55die  thanks for the reply. Tried the factory reset you suggest. It won't connect to broadband now. The broadband is working fine for all other devices at home and the power line adaptors are both showing the correct lights.. I've not yet found an answer in the community for this issue. Any ideas. Thank you
fre55die
Message 5 of 6
Hi @WelshNess
Try a factory reset from the main menu. Blue YV/Menu button on remote then up to settings (cog wheel) > Factory reset (bottom right).
VERY IMPORTANT FOR STAFF SUPPORT !!
Thank you
