on 15-06-2021 10:02 AM
After many years, my recordable box is now starting to have a few issues. I have always found the box pretty reliable, and easy to use.
I am aware that talktalk no longer supply recordable boxes, so what are the implications if i purchased one of these off ebay, other than the obvious one(faulty).
Would i be able to connect to my existing network issue free?
thanks
15-06-2021 12:07 PM - edited 15-06-2021 12:09 PM
Any box will work, just avoid the older ones as Karl mentioned, the Humax DTR-T1000 and DTR-T1010 are also defunct.
on 15-06-2021 12:00 PM
I notice some are talktalk boxes, and some are BT, will it matter which one?
Thank You for the answers
on 15-06-2021 10:27 AM
Agree with ferguson, box will work just fine, as long as it is one of the models that support the Now TV app. The DN370T model does not support these so steer clear of that one.
on 15-06-2021 10:12 AM
Any YouView branded box will work just fine.
