Youview Box
Isla1986
Sightseer
Message 3 of 3
I'm having major issues with my youview box. The red and blue light is forever flashing, I need to rest it multiple times a week, even sometimes a day. Would it be possible to be sent a replacement box as it's getting to the stage that I don't even try to switch the TV on as it takes so long to rest the system. Many thanks.
Message 1 of 3
Hi Isla1986
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
Message 2 of 3
When you say reset, have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the support staff look at other alternatives.
Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones., So it's best to try all alternatives if recording is important to you.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
Hope it works but if not then please let us know and I’ll flag for further assistance.
