Youview DN360T box and remote not working
Charlotte2106
Message 5 of 5
My remote light will light up when pressing buttons but it doesn't do anything and the box will only turn on and off can't even change the channels on it. I've reset the box, changed the batteries, reset the remote. Nothing is working
4 REPLIES 4
Message 1 of 5
Should be out in 24-48hrs
Charlotte2106
Message 2 of 5
Oh thank you very much. How long will it take to receive
fre55die
Message 3 of 5
@Charlotte2106
Try a factory reset details here https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode/
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
Message 4 of 5
I'll get a replacement TV box out to you.
