Youview Disk Storage
YouviewQuery
Message 2 of 2
I have been using my TalkTalk Youview recorder successfully for many years. It is a Huawei model DN372T. I would like to transfer some films I have recorded to my computer. The Huawei device has a USB port on the front and also at the back. When I connect a USB cable from either port to a laptop, neither port is recognised.
Is there any way of transferring data from the Youview recorder to computer?
1 REPLY 1
Gondola
Message 1 of 2
Hi YouviewQuery
Sorry to report that there is no direct transfer permitted.
GondolaVolunteer 2017-2022
  Like below to appreciate my help . . . Mark as solved  Accept as Solution
