Youview box and Smart TV
AliM12
Message 9 of 9
How do I connect things up so I can use the youview box and use smart tv? I know I should just use the source button, but i must have set up of cables wrong as smart tv not getting signal on its own.
I am using a TT WiFi extender too, so i have yellow Ethernet cable plugged into that and box, aerial plugged into box too. Really I just want to use Smart tv for YouTube viewing. What am I doing wrong?
Ali
8 REPLIES 8
Message 1 of 9
Hi have u tried contacting Samsung tv company to see what they say would work or if u TV needs a update on it
SO ur tv can not find ur wifi whats the signal like in the room on a phone or tablet??
What make and model do u have for ur TV??
and what fre55die says it helpful.
Be fore u had talktalk TV how did the TV connect to the router for internet
What i think Fre55ide is saying u could have one of the following pluged into the talktalk powerline by ur box& tv then have a network cable going to the tv box and another going to the tv.
or u could get a tp link kit which has 2 eithnet cable sockets like this
https://www.tp-link.com/uk/home-networking/powerline/tl-pa4022p-kit/
a friend of mine has a bigger set of these
https://www.tp-link.com/uk/home-networking/powerline/tl-wpa4220-kit/
I use to tp link as i found using a extinction lead with talktalk basic kit for poerwlines worked ok but could not plug into the wall
So i have tp link which has a front cover plug and work fine
Hope that help Regards Joe
Message 2 of 9
@AliM12
I've not tried this route as I prefer hard wiring where possible. As I said, I use the switches and some things are on long ethernet cables. The switches are tiny (9.4 x 10.1 X 2.9 CM) so will fit anywhere.
I notice that this uses USB so I can't see how they would work on a TV 26% of customers say it is useless which is pretty high.
https://www.amazon.co.uk/Velidy-Wireless-dual-band-WIS12ABGNX-WIS09ABGN/dp/B0785Q4J9K
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
Message 3 of 9
@AliM12
These then also give internet to my NOW TV box and Bluray player as I find hard wired far more reliable and solid than Wi-fi connections.
Message 4 of 9
Thanks, I'll take a look, but I can't use a cable as tv is too far from hub.  A web post suggested one of these. Might give it a try.  Thanks.
https://www.wish.com/c/5b60454516e1e919f0c60c58?hide_login_modal=true&from_ad=goog_shopping&_display...
Message 5 of 9
Hi @AliM12
I use a number of these
https://www.amazon.co.uk/TP-Link-TL-SG1005D-Desktop-Gigabit-Ethernet/dp/B00ZOOJXEG/ref=sr_1_5?keywor...
And a couple of these
https://www.amazon.co.uk/NETGEAR-Ethernet-Unmanaged-Internet-Splitter/dp/B07PYSNSDD/ref=sr_1_4?keywo...
Message 6 of 9
Yes, a Talk talk WiFi extender. I realise there is no internet to tv as not connected via cable. Tried to turn on WiFi but says it's unavailable. Must not be WiFi enabled. Saw online I could get a Samsung Lan adapter, do you know what that is?
fre55die
Message 7 of 9
Hi @AliM12
Have you set up the WI-FI on the TV as it will need an internet connection for the SMART functions on it to work. I am assuming that you do mean a WI-FI extender not just a standard Power Line Adapter.
hosay299
Message 8 of 9
@AliM12 Hi so can i check how the smart tv get internet connection ??
