Youview box doesn't have amazon prime or Netflix on it?
Jazzk
Message 3 of 3
Set up correctly but it dose not have amazon prime or Netflix?
Message 1 of 3
Hi Jazzk
If you have the DN370T model this will not support the apps such as Netflix etc, however all other models do.  Which do you have ?
Message 2 of 3
Which box do you have?
Within settings, try updating the apps to see if this forces them to install.
if not then depending on your box, if a recordable one try a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
You will then need to reset your personal settings (such as parental controls / Set antenna Out to On in Settings: Picture and Sound / Surround Sound etc.) and also reset your scheduled recordings (might be worth taking a note of future recordings before doing this so you don’t miss any
Or if a non recordable box, try a full factory reset from the settings menu.
Hope it works but if not then please let us know and I’ll flag for further assistance.
