Youview box faulty
Nickyw71
Message 8 of 8
my youview box is not working properly, very slow waking up then randomly goes off with no channels  to view
any help please?
7 REPLIES 7
Message 1 of 8
Can  you add your home phone number to your 'Community Profile' so we can locate your account.
Message 2 of 8
Yes would like a replacement box urgently please as it has now stopped altogether, thankyou
Message 3 of 8
Hi Nickyw71
Apologies for this.
I can send you a replacement TV box but just to make you aware we no longer send out the recordable boxes.
Would you like me to order this for you?
Message 4 of 8
Thanks for that , I have tried all those options and it’s still shutting off , think might have to request a new box ?
Nickyw71
Message 5 of 8
Tried the re set option & re set to default etc and it’s still just randomly shutting off , had the box for over 5 years now , never had any issues until now
Message 6 of 8
Hi Nicky,
Try the resets as advised and let me know if performance improves.
Message 7 of 8
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones., So it's best to try all alternatives if recording is important to you.
Hope it works but if not then please let us know as you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
