Youview box is broken
RebeccaB11
Message 3 of 3
My Youview box is always playing up, just straight up freezing mid show and have to turn off at the back to unsort which takes ages for setup. If you try and use any of the apps it also freezes, if you leave it on pause too long it freezes and you have to turn off. And this last week the recording have not been working they play but just a black screen, you can ff and pause etc but just all on a black screen. Would love a new box as something is not correct with this one and it's pretty old.
RebeccaB11
Message 1 of 3
Thankyou, seems to have help with use of the apps so I will have to see if everything else is sorted
fre55die
Message 2 of 3
Hi @RebeccaB11
Have you tried a maintenance reset OPTION 2 which keeps your recordings :
Maintenance Reset Option 2 (Keep Recordings)
Turn the box off, then unplug the power lead for about 10 minutes.
Re-plug in power  lead.
  1. Ensure the YouView Box is switched off and is currently connected to the router (the YouView Box will require an internet connection).
  2. Power on YouView using button at the back of the YouView Box.
  3. Start YouView using the power button on the YouView Box front panel and then quickly press and hold both the + and – buttons on the front panel. If you haven’t pressed the buttons together by the time 'YouView Waking Up' is displayed, or you see the 'YouView please wait...' message then try again.
  4. Let go of the + and – buttons once the 'Huawei – Maintenance Mode menu' is displayed.
  5. The + and – buttons on the front panel will navigate the menu. Keep pressing the – button until 2  “factory reset keep recordings” option is highlighted.  If you go past the option, simply press the + button to navigate back to the option.
  6. Press the power button on the YouView Box front panel to select the option. This will bring up some information and ask 'Do you want to proceed?'. Press the power button again to confirm.
  7. The YouView Box will now show a progress bar as it downloads software from the internet and installs on the YouView Box. This may take several minutes. Once complete, the YouView Box will restart.
  8. Once the YouView Box restarts, the YouView Box will show the initial setup wizard. You will need to run through the setup wizard including tuning the channels.
You will then need to reset your personal settings (such as parental controls / ANTENNA OUT / Surround Sound etc.) and also probably reset your scheduled recordings (It might be worth taking a note of future recordings before doing this so you don’t miss any).
If you do NOT have any recordings that you want to keep :
Blue YV /Menu button on the remote  >  Settings  >  Factory reset. This option will re-format the hard drive and reinstall the system on your box and you will lose all recordings.
Again It is also a good idea to restart your router once you have done this.
TT are no longer issuing recording boxes only "Lite" boxes so do try this.
IMPORTANT !!!!!!
Could you please ensure that your personal information is up to date in your profile.
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
