Youview box keeps freezing
Davidaxon
Message 3 of 3
The youview box is freezing more and more frequently, this started before last Christmas. Sometimes It won’t record prearranged programmes. I have used online chat and the person I spoke with said that this was a common problem and the engineers were ‘out and about resolving the problem’. He said to check back in  24 hours and it should be solved. I don’t think he understood the problem despite me explaining it twice. I have reset it every time it freezes, but haven’t reset it so it deletes the recordings. I would be grateful if you could contact me to resolve this. Model no. DN372T.01.02.P
Message 1 of 3
Hi Davidaxon
Please try the resets as advised by fr8ys and see if this helps.
Message 2 of 3
If you have tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347) then the only thing left to try is a Factory Reset from the settings menu. You will lose your recordings, but as TalkTalk no longer provide recordable boxes in exchange, if you are eligible for a replacement, it is the only way you will be able to record going forward if the reset does repair the hard drive, which has become corrupted.
Let us know how you get on, as you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
