Youview box not playing recordings
DandD
Message 3 of 3
Hi there, I was watching an episode of a series I had recorded, when it finished I went to play the next one, but the screen was blank. I tried to play another recorded programme, same thing happened. I switched off at the back of the box & restarted & tried to record something new, it failed to record, what else can I do? Thanks for your help!
Message 1 of 3
Try a Youview Maintenance Reset  and see if this helps.
Message 2 of 3
have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives. Please also be aware that TalkTalk no longer provide recordable boxes, only the lite version, so if you require recording then these are really your only option.
Hope it works but if not then please let us know and I’ll flag for further assistance.
