Youview box not working
Ricky792
Message 8 of 8
Hi - my Youview box has stopped working, I can't get it to turn on (no blue light, nothing). The power supply is OK, the powerline adaptors seem fine and the aerial works when I plug it direct into the TV so I assume the box has given up. Can I have another one please?
Rick
7 REPLIES 7
Ricky792
Message 1 of 8
Thanks, fitted these and everything now working properly. Cheers.
Ricky
Message 2 of 8
OK, I'll swap out the adapters and see if they are causing the problem.
Message 3 of 8
The new box arrived and is working - but it can't connect to my broadband! It seems to me that the powerline adaptors aren't pairing (they were fine before the old box broke, obviously) - I've followed the online instructions including the factory reset but not had any joy getting them to pair to each other (though my adaptors aren't 'wireless' so the lights aren't exactly the same). My broadband is working fine and the lights on my router are green (except for TV of course).
Any ideas?
Ricky
Message 4 of 8
Hi Ricky792
I'll get a replacement box out to you.
Message 5 of 8
OK, wait for the support team to advise further. Make sure that your personal details including TalkTalk landline number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
Ricky792
Message 6 of 8
Thanks, but I can't get the box to turn on at all and I think it needs to be on for the maintenance mode reset to work.
Message 7 of 8
Have you tried a maintenance mode reset as described here?
https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347
