Youview box stuck on wake up screen
dboyers
Message 5 of 5
Hello, I am having issues with my talk talk (youview) box.  When I turn the box on, the lights on the box illuminate as usual but I cannot progress past the initial wake up screen.    I have followed the advice on other posts, turning off / on again, going to maintenance mode, doing full factory reset but none of these are working.  I have had to plug the box out at the mains as it is getting really hot.  Can I please request a replacement box,  It is a Huawei model: DN36OT.
Many thanks, Dwayne
4 REPLIES 4
Message 1 of 5
No Problem 🙂
Message 2 of 5
Thank you very much Karl
Message 3 of 5
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
fre55die
Message 4 of 5
Hi @dboyers
I have escalated this to OCE support and they will respond on here A.S.A.P.
Please do not add anything on here OR start a new thread until an OCE responds as the system will see this as a new post and move you to the back of the queue.
Unfortunately the response times are extremely delayed and currently can take a couple of days instead of the usual matter of hours. Please bear with us as an OCE will get back to you as quickly as possible.
