Youview box wont start up
6 REPLIES 6
voukos
Worked fine yesterday evening. Same socket, same place. Disconnected everything, then reconnected but to no avail. Tried using chat, but there is nobody available
When you say it won't start up, are you getting anything on screen at all?
Are any lights on when you try to turn the box on (if not have you checked the fuse)?
If you are getting the box to actually begin to start then have you tried a YouView Maintenance Reset
Hope it works but if not then please let us know and I’ll flag for further assistance.
voukos
thanks for the feedback. No lights, nothing at all. Completely dead
Ok, I've escalated for you, but just to check, have you changed the fuse in the plug?
voukos
thank you. doesn't have a plug. it has a 12-volt transformer
Doh, silly me!
OCE_Karl
Hi voukos
A replacement Box is on the way,
