box not recording or playing back
andyaroberts
Message 6 of 6
I'm no longer able to record or play back on my set top box.
I am now getting a message telling me the programme has failed to record. And even if I go to programmes that were successfully recorded earlier I am no longer able to play backI
I have rebooted the box but without success.
What more can I do?
How do I check if the box is full & no longer able to record?
Do I need a new box?
I'm sorry but I'm really not tech savy & am struggling with resolving issues when there is no-one to speak to - I'm very much hoping you can reassure me & help me sort this out.
Thanks,
Andy & Liz Roberts
5 REPLIES 5
Message 1 of 6
Hi Andy,
Keep an eye on things, and any issues, just let us know here.
Message 2 of 6
@andyaroberts pleased to hear my suggestions worked and the box is now behaving itself.
Message 3 of 6
Hi Michelle,
Thanks for your suggestions.
I worked my way through them even though the box didn't perform as the notes suggested it might: At no point did the box offer to 'start up'
Nor did it offer the maintenance reset programme, although I could just read this behind the screen text. However, the message eventually became clearly visible. I ran the maintenance reset but the result still didn't allow me to record/ playback so I opted for factory reset. Shame to loose what I'd recorded but on the basis I couldn't record/playback anyway I opted for this and - it worked and I'm now able to record & playback again. I only hope it continues to behave! Thanks for your help.
Andy
Message 4 of 6
Hi andy,
How are you getting on?
Message 5 of 6
Have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
