error 501 on start up
Bramble2
Message 10 of 10
I tried to start my Youview box today and it went into maint mode with error 501.
I carried out the suggestions in the FAQ ie reset to factory default saving recordings, this didn't work, so then I did the same deleting recordings.
I also tried the carry on to restart option, all that happens is the box stays in wake up mode, after leaving it for a long period with no success I turned the box off again.
What am I doing wrong or is there a fix?
9 REPLIES 9
Message 1 of 10
No Problem 🙂
glad the new box is working as it should.
Message 2 of 10
Managed to fight through the snow and icey roads.
Installed the new box today, all working great.
Now to put my feet up and chill in front of the TV after a hetic Journey.
thanks again Karl
Bramble2
Message 3 of 10
No Problem 🙂
Set the box up when at home and just let me know if there are any problems.
Message 4 of 10
Just to let you know, the new box arrived today,  although I am stuck away from home until possibly the weekend.....snow what snow!.......so won't be able to connect up until then,
however many thanks for your prompt service.emoticon.thumbsup.title
Message 5 of 10
No Problem 🙂
Message 6 of 10
Wow that's great
Thank you
Message 7 of 10
I'll get the box replaced for you.
Message 8 of 10
Yes.
I am now at the stage where we have disconnected the Youview box
So we can watch TV through the aerial.
Message 9 of 10
Hi Bramble2
Apologies for the delay.
Are you still experiencing this fault?
