huawei dn370t freezing
PTwynamP
Message 10 of 10
I have had the TV box for a while and it has just started to freeze, like several others I have just been reading about. I have tried all the maintenance fixes to no avail. it does not respond to the remote at all.
Hope you can help
PTwynamP
PtwynamP
9 REPLIES 9
Message 1 of 10
Glad this has resolved things for you.
Message 2 of 10
Hi Karl,
just to say that the new box arrived today and so far it seems to be working.
Many thanks for your help.
PTwynamP
PtwynamP
Message 3 of 10
It's usually 24 - 48hrs.
Message 4 of 10
Thank you for that.
any idea when it may arrive?
PTwynamP
PtwynamP
Message 5 of 10
I've a replacement box on the way to you.
Message 6 of 10
I have updated my profile as requested.
PTwynamP
PtwynamP
Message 7 of 10
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
Message 8 of 10
thanks for your reply.
I am not able to try this as the box won't go past the 'Loading' screen and so I can't access anything. (that is when I can get it on at all!!)
Peter
PtwynamP
Message 9 of 10
Can you try a full factory reset from the youview menus.
Set the box back up and see if performance improves.
The factory reset will fully clear the hard drive of all content and set this back up.
