17-04-2018 07:11 PM - edited 17-04-2018 07:20 PM
I used to experience some occasional buffering while on an otherwise very good ADSL2+ connection. Since switching to Fibre Medium (again seemingly a very good connection) earlier this month, I'm shocked to discover that the buffering seems to happen more often and will often occur 2 -3 times during a one hour tv programme.
The buffering wheel spins until eventually an iPlayer error message appears, pointing to a possible loss of internet connection. At that point even data for the Youview Guide fails to appear.
I have to come right out of iPlayer, wait for a couple of minutes then go back into the programme via the Guide. This can happen at any time of day, but recent events have occurred mid to late afternoons. The Youview box is connected to the router via Devolo Powerline Adaptors. HG633 Router with latest v2.0 firmware.
Help - Please advise how this issue can be overcome.
Answered! Go to Solution.
on 28-05-2018 01:02 PM
@paulshent wrote:
I am now waiting for their latest Sagecom router to see what it's process speed is like.
Hi again @paulshent
Yes the new Sagemcom sounds interesting. I spotted a short review from the ISPreview website..
26-05-2018 01:39 PM - edited 26-05-2018 06:51 PM
@paulshent wrote:Hi. First thing let me say is that i do not work for TalkTalk, and that i am passing on what i found during testing and how i got around the issues.
Your software and box are at the same level as mine. So no problem.
I have now moved my settings back to 1080p without any issues, since i had the xx.xx.145 release of software.
Thanks. I've had xx.xx.145 software for about ten days now and it did not cure my buffering issues.
I find it a lot faster than previous release.
What i did find (and still do), is that if i use an HG633 router on ANY release version of firmware inclusive of V2.0, then i get breakups, network loss and / or pixilation of the channels. I even got an issue where the router would just for no reason reboot. This issue applies to both my tv boxes. One is connected with direct ethernet cable the other over TalkTalk supplied network wall plugs.
Once i got hold of an HG635 (TT used to supply these), and used that then my network breakup / pixilation / dropout issues stopped. So in other words since i started to use an HG635 my issues went away. To be honest i don't think the HG633 is of any use except for standard none TV usage.
Having made my internal networking / socketry changes (as I've detailed in this thread) I'm so far finding that my HG633 seems to work just fine for tv usage (Note: I basically use the TT box for watching and recording the Freeview channels, Catch-up players and Netflix only).
An HG635 can be had from E-bay and is a TT supported router.
Hope that helps a little
Interesting, thanks. Have to say though, with respect, nothing you have revealed is tempting me to go back to my old setup, as even the latest TT box software update did not cure my issue before I made those changes. The HG633 now seems to work for me so I guess 'if it ain't broke'. I'd still prefer to have the Router located where it used to be (ie.in the Primary Master Socket room), but it's a sacrifice I'm prepared to make, as it means I'm finally rid of the dreaded buffering.
aa2000
on 26-05-2018 11:46 AM
I have now moved my settings back to 1080p without any issues, since i had the xx.xx.145 release of software. I find it a lot faster than previous release.
26-05-2018 08:58 AM - edited 27-05-2018 08:40 AM
I have just finished running the trial on multi room
So i suggest you change following until you have latest software uploaded to your tv box
Undersetting i assume your tv is set to 1080p
Just reset this to 720p.
Buffering will then stop
Once you have latest software auto updated then you can reset back to 1080p
Tell me what type of box it is and level of present software. Will then tell you what to look out for.
Both the recordable tv box and the Multi room box will run fine over the mains supplied network extenders.
Hi @paulshent
Encouraging to hear this.
You claim that with the latest software that you've just finished testing that "Both the recordable tv box and the Multi room box will run fine over the mains supplied network extenders". To what extent had you experienced buffering yourself previously and on which players? Difficult question maybe, but how sure can you be that the latest software you're referring to will definitely cure the buffering problems that I described? Sometimes local electrical issues have been known to defeat even the best of PLA's.
Did you see how I have now managed to overcome the issues? I'm very grateful for your advice but having now taken the time and trouble to make these changes, I'm understandably a little bit reluctant to revert to my previous setup without further solid assurances and ideally additionally from a TTTV Trials Team member.
Just to add, with my new setup, while it has overcome the buffering issues, I would actually prefer to have the router in its former more discreet location (in Primary Master Socket room) rather than under the tv (which is on a glass stand) where it's hard to conceal its flashing lights. Ironically, I'm still now using the Devolo PLA's to feed my laptop in the room where the Router used to be located.
Box: DN372T.01.02.P
Current Software: 72.45.145
aa2000
on 25-05-2018 11:57 PM
Hi.
on 25-05-2018 01:00 PM
Thats great, thanks for keeping us updated.
25-05-2018 12:47 PM - edited 26-05-2018 06:20 AM
Success. I'm pleased to report I've managed to convert a redundant extension phone socket next to my tv equipment into a secondary Master Socket (MS) and rewired the primary Master Socket, to take advantage of its A and B terminals. Connecting cable is Cat5e so perfectly good. Have now connected router to the secondary MS and everything is hunky dory, no buffering and no significant degradation in speeds.
08-05-2018 09:45 AM - edited 08-05-2018 04:56 PM
Thanks Karl, much appreciated. I shall also drop the Trial Team a line with a link to this thread.
aa2000
UPDATE: 08 May :
Apparently I'd somehow been dropped out of the trials due to my Fibre upgrade. This most likely explains the older software. I'm now being reinstated next week.
on 08-05-2018 09:16 AM
I've dropped an email too the trial team to look at this. I notice the STB firmware is not the latest, and this may be on a trial firmware so I cannot change this, so I've flagged this to them. you may want to also contact your trial contact your self so they can pick this up.
04-05-2018 09:58 AM - edited 04-05-2018 10:07 AM
Here's what tends to happen:
The programme starts to buffer. After some seconds of buffering I get an iPlayer 02100 Error Message..
"Something went wrong playing this programme. This is usually a temporary problem. If it continues
I then exit the player and return to the Guide to once more find the programme, only to find that the Guide is snarled up displaying "No information available" in place of programme information. Generally, If I exit the Guide and return to it after a minute or so, this clears the problem, allowing me to resume the programme, but the whole problem (buffering etc.) will often repeat minutes later.
All very annoying especially since I supposedly have such a good connection.
on 03-05-2018 08:05 AM
Thanks Ady. I'm a TalkTalk tv triallist in case that makes any difference.
aa2000
on 03-05-2018 07:59 AM
That's great thanks for the information. I'll raise this to the TV escalation team for investigation. I'll post back to let you know it's sorted.
on 02-05-2018 01:19 PM
@Ady-TalkTalk wrote:Hi aa2000, I've run a line test and your line is great. Speeds look good. Have you reset the box? If you watch IPlayer on your TV directly do you get the same buffering?
Hi @Ady-TalkTalk . Yes I did a complete box reset just a few weeks ago. I don't get the same buffering when I watch iPlayer on my tv directly (also fed via the same set of Powerline Adaptors).
on 02-05-2018 01:12 PM
on 02-05-2018 12:54 PM
No. I would like an OCE to investigate based on my existing setup which would point to my adaptors not being the cause.
on 02-05-2018 12:46 PM
Have you managed to get hold of that long cable yet so you can try connecting the box to the router directly?
on 02-05-2018 12:38 PM
Can an OCE please investigate this issue? Thanks.
Please note..
on 17-04-2018 08:30 PM
OK, not much more I can suggest I'm afraid, other than buy a longer ethernet cable (cheap as chips).
on 17-04-2018 08:09 PM
@ferguson wrote:Not even temporarily moving the box/router? Or getting a long ethernet cable? It really is worth ruling out the adapters before looking elsewhere.
Much as I'd like too, my longest Ethernet cable isn't quite long enough and I'd otherwise have to move my tv to a room on a lower floor. I really have no reason to suspect the adaptors as they satisfactorily serve the tv directly too and provide consistent YouTube and iPlayer connectivity via that link.
on 17-04-2018 07:52 PM
