issues with watching iplayer on smart tv
jakescott54
Message 4 of 4
I have recently changed to talktalk internet. However, when i try to watch Iplayer on my smart tv, it works for around 45 minutes, then shows the buffering symbol and kicking me off, but it also says the connection of my internet to my TV is fine, so I'm not too sure what the issue is.
3 REPLIES 3
Message 1 of 4
Is the Smart Tv connected over WiFi ?
Please add your phone number to your 'Community Profile' so I can look at your connection.
Message 2 of 4
Oh and you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
Message 3 of 4
Are you accessing iPlayer via the YouView box, or your Smart TV?I
What happens if you watch it on the other device? Is it OK or does it display the same symptons?
how do other players And internet accessed apps play? Ok or cutting out?
What download speeds do you get?
how is your box connected to the router? How is the TV connected?
If you can provide a bit more background we may be able to offer advice
