powerline adapters not working
JasperJackal
Message 3 of 3
I have been through all the advice re resetting the adapters. I have had them side by side, I have pressed the reset button, I have paired them and I have switched them off for 30 or more seconds. I have done all this several times and still I cannot get the adapters to talk to each other
Message 1 of 3
Hi JasperJackal
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
fre55die
Message 2 of 3
Hi @JasperJackal
IMPORTANT !!!!!!
Could you please ensure that your personal information is up to date in your profile including your registered Landline Phone number.
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
