recording and replay fails
oddmundb
Message 2 of 2
our recordings won't play back
fails to record new content as well
all checks done, latest software is present, all leads checked
1 REPLY 1
Message 1 of 2
Try a Youview Maintenance Reset and see if this helps.
If that fails then the only option is to try the full factory reset from the settings menu, erasing all content in case of any corrupt files etc.
