on 16-12-2021 03:25 PM
Hi has anybody else had the problem of the sound dropping out while watching either a recording or live TV through the settop box when it returns after a few seconds the sound and picture are out of sync. To get it back as one have to turn the settop box off and then back on (this corrects the problem but only for a few minutes).
If I watch through the TV only i have no problem?
on 20-12-2021 07:45 AM
try the maintenance reset as advised and let me know if this helps.
18-12-2021 06:46 PM - edited 18-12-2021 06:48 PM
Hi @Thefish21
The other thing to try is a Maintenance Reset (option 2). This often cures all sorts of problems : https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode/
on 18-12-2021 12:03 PM
Hi Michelle,
Would be great if you can help me sort this problem out as it makes watching TV a real pain!
Thefish
on 18-12-2021 12:01 PM
Hi fre55die'
Sorry to say it did not work, have ordered new HDMI cables (should have them by Monday) and will try again. Will keep you advised of the outcome .
Thefish
on 17-12-2021 06:05 PM
@Thefish21 Do let us know if it works.
on 17-12-2021 05:00 PM
Hi fre55die, will try the leads tonight and see if that help thanks
Thefish
on 17-12-2021 06:48 AM
Please let us know if you still need assistance with this.
on 17-12-2021 01:13 AM
Have you tried either new HDMI lead or at least swapping the ends over of your current one I.E. the one connected to the box becomes the one connected to the TV?
