talktalk box continues to crash
hikerdudie
Message 2 of 2
I'm frustrated by the number of times that the talktalk box crashes and i have to reboot it.
Is there a solution for this?
1 REPLY 1
Message 1 of 2
Can you try a Youview Maintenance Reset (Option 2: Keep Recordings).
Set the TV Box back up and see if performance improves.
