tv antenna signals even after cable is connected to set top box
vitachaos
Message 2 of 2
My talktalk set top box is connected to tv antenna, but something broke few months back and now tv setup box is not getting signals, can anyone please help me who to call to get the tv antenna or signal fixed ? thank you in advance.
1 REPLY 1
fre55die
Message 1 of 2
Hi @vitachaos
TalkTalk does not deal with actual aerial problems. If you connect the lead directly into your TV do you get a picture and the full selection of available channels?
If not you will need to contact a local aerial installer to sort it out for you I'm afraid.
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
