on 17-02-2022 08:04 AM
My tv plus box yhe picture is breaking up I have checked the signal strength and it is 41%.On my tv the signal stength is 90%.This is connecting the aerial direct to the tv.I have tried retuning and a factory reset but it makes no difference to the signal strength through the tv box when recordings are played back these are also messed up any help would be appreciated thanks
on 24-02-2022 02:57 PM
Ok, thanks for confirming.
on 24-02-2022 02:56 PM
Yes all parceled up and sent back thanks
on 24-02-2022 02:04 PM
OK, have you got a returns bag ?
on 24-02-2022 02:01 PM
The new box you sent me I am sending it back I have decided to buy a tv box that records programmes but thank you very much for all your help.Thank you
on 23-02-2022 08:48 AM
You're Welcome 🙂
on 23-02-2022 08:46 AM
Thank you.
on 23-02-2022 08:44 AM
I'll send a box now.
on 23-02-2022 07:30 AM
Sorry to bother you again would it be possible to send me a new box out please as it is not really worth using recordings thanks
on 17-02-2022 08:36 AM
OK, I'll hold off on sending the box.
on 17-02-2022 08:35 AM
We record quite a lot I dont think it would be benificial to have an ordinary box whe I can get freeview through my tv
on 17-02-2022 08:24 AM
I can swap out the box for another to see if that helps. We no longer provide a recordable box so this would be the DN360 model, would you like to try that ?
on 17-02-2022 08:22 AM
Tried both signal strength still in low 40s
on 17-02-2022 08:09 AM
OK, let me know how it goes.
I have not I will try it now thanks
on 17-02-2022 08:06 AM
Did you also try a retune without the aerial connected, then a retune with the aerial connected.
