tv
sarah1231
Message 2 of 2
I cant watch tv through my talk talk box i have to unplug the aerial and put it back in my tv so i can watch tv why is this thankyou..
1 REPLY 1
fre55die
Message 1 of 2
Hi @sarah1231
Have you enabled the aerial passthrough ? YV button > Settings > Picture and sound and its the last setting.
