youview box keeps freezing and doesn't record everything
TrigUK
Message 7 of 7
fails to record everything and keeps freezing when playing back recordings
6 REPLIES 6
Message 1 of 7
No Problem 🙂
TrigUK
Message 2 of 7
I've tested it over the past few days and seems to be mostly OK now. Thanks both for helping me.
All the best 😊
Message 3 of 7
No Problem 🙂
TrigUK
Message 4 of 7
Thanks both. Have tried the reset and will see how things go today. It does seem a little bit more responsive now but will update you again once I've tested it
Message 5 of 7
Hi TrigUK
Try the reset advice above and let me know if this helped.
fre55die
Message 6 of 7
Hi @TrigUK
Have you tried a maintenance reset OPTION 2 as follows, be aware that TT are no longer issuing boxes that record
https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347
