youview box stuck on loading
1953kev
Message 5 of 5
A few weeks ago my Huawei YouView box started to freeze on the current channel I had on. It wouldn't let you change channel or open any of the guides or players either. I had to keep switching it off and back on again. Today  I switched it off on the back, after switching it back on it went into Maintenance Mode and I tried all the options and it still fails to load. after which I switch it off at the back to start it up, it then just keeps showing the loading screen. It has currently been on loading screen for over an 2 hours
4 REPLIES 4
Message 1 of 5
Hi 1953kev
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Message 2 of 5
hi @1953kev
I have escalated this to OCE support and they will respond on here A.S.A.P.
Please do not add anything on here OR start a new thread until an OCE responds as the system will see this as a new post and move you to the back of the queue.
Unfortunately the response times are extremely delayed and currently can take a couple of days instead of the usual matter of hours. Please bear with us as an OCE will get back to you as quickly as possible.
Message 3 of 5
ok done that
fre55die
Message 4 of 5
Hi @1953kev
IMPORTANT FOR SUPPORT
Please post back on here when you have done this and I shall Escalate this for OCE support.
