I'd like to opt out of TalkTalk TV (£4 monthly charge) as I dont use any of the services that this charge provides.
Many thanks,
James
Hi James
I can opt you out of the upcoming TV charge but I'll need to confirm some security details to access your account. I'll send a PM separately with the info required.
Please note however that when you opt out of TalkTalk TV you will lose access to add and remove TV Boosts flexibly. You will lose access to TV Boost on demand content via the TalkTalk player. You will also lose access to TV on the go services via the web and Mobile App.
Also, any current recordings you have made from a Boost channel will stop working when you are no longer subscribed to that channel.
you currently have an active entertainment boost. This will also be removed, is that ok.
Yes please, turned it off earlier. Not really used it much.
