£5 discount code
Visitor
Hl,
Can anyone help please ? I cant find the £5 discount code which is normally at the bottom of the screen in showcase when I go into more tv. Is this no longer available or has it been put somewhere else ?
Many Thanks
Lizzie
Same here, dont recall seeing it this month. Restarted the router (off for 5 mins) which has solved the issue in the past but still nothing. Gave up in the end.
Hi Lizzie78,
Apologies for the delay.
I'm sorry you haven't received your £5 TV voucher code. Can you advise if you've switched off the router for 30 minutes and re-set the TV box?
Thanks,
Jo
