5USA
Watching 5USA fir the past hour and suddenly YVM102 message. All connections are fine. Ays ok fir 20 seconds and then same error message. No wind no rain cm night. Tried other channels like Pick and Yesterday. Same thing. I've really had enough of TT. Honestly. Been with them nearly 16 years and this last year has been a nightmare.
BAR
Hi @Barann
It is nothing to do with TT see this from FREEVIEW, the same warning on YouView pages :
Current high pressure weather conditions across parts of the UK can cause picture break-up or loss of channels. If you are affected please do not retune your TV, as reception will improve with the weather.
If you have a Freeview Play TV, or an internet connected TV, you can watch live and on demand content through players such as BBC iPlayer, or ITV Hub.
Alternatively, you can also stream live TV via the Freeview mobile app.
Hi Barann
In addition to fre55die's post, you can also read the following on the BBC : https://www.bbc.co.uk/news/technology-50945421
Freeview are having issues across the country at the moment.
